Spindles
I already have thanks. it shows them as two different part numbers so I was wanting clarification. I have seen the same part having two different part numbers or an updated part number...
Pro in front Assault in the back.
Sent from my SM-G920V using Tapatalk
Thanks for the pic LPIdaho, I was curious because I have a set of 39" zbroz a arms I'm going to put on my assault and will be using the stock ball joints, so I want to make sure this will work or will I need more parts?
That's probably why my Assault feels a little different... That 5-10 degree caster angle change would make it better for trails .. and more like the Skinz geometry
Got the zbroz a arms on and seems to me there is a lot of play (front to back) on the plastic bushings/metal shafts that bolt to the bulk head. Mostly on the upper arms but little on the lowers, is this normal?
The stock arms have lots of play as well.
If you want to tighten it up, I went with the Zbroz brass bushings. They have a shoulder to take up the slack, as well as a shim kit so you can get it exact.
