Spindle Alignment
Kyle.laabs
Just bought 06 spindles for my 05 rmk (wore it our in the weak tie rod hole). can someone tell me step my step what to do please to align them? ive found articles that explain pieces but its my first time and cant put the pieces together. Any help is appreciated as always! Thanks guys
FYI If you were looking to update your spindles to help reduce your steering effort you should have gotten 08 or newer spindles. Okay, first you have to set your camber, jack the sled up off the ground with the skis removed and put a 5/8" bar that is 45" long through the spindle on one side so that it hangs below the other spindle and measure from the top of the casting that sticks out for the bushings. Not sure what the specs are for the RMK. Then you need to make sure the skis are straight and aligned with the track and then set them so that they are toed out 1/8"-3/8". Make sure everything is tight and you should be done.
Alright thanks alot! really appreciate it! and i realize the newer spindles are better, plan to but a new a-arms and spindles this summer. just picked up this set for $50 so i could finish the year! thanks again!
