Spark issue
Well it maybe an issue but im wondering how bright the spark should be when pulling the sled over with the plugs out? Its hard to see in daylight but if i turn out the lights i can see what looks like a decent spark, just finished draining the crankcase... cylinders and pipes of fuel and tryin to fire it back up after the temp sensor went and ran like a bag for a bit. Now its being a bag to start up again even with new plugs i dialed the air screw in and then back out 1.5 turns and the other white one out 3/4 turn but the pig wont fire lol.. i checked the carbs they are all clean and floats appear to be working normally i flipped them over and blew air into the fuel line end and it wouldnt go through til i flipped them back over to right side up. i didnt change anything there but im getting frustrated now. Prob more of tired of pulling it over i think. I just wanted to see if it might be a weak spark issue.
if your both sparks are sparking fine, its fine. I would use the lighter to fire it in one of cylinder to see if its fireable enough with fuel in it. both plugs have to be off.
I dont know what else to think about unless you tell us what year, model, engine size is your sled?
spark issue
Well coil is good got it fired today.. was a pain but once i got the fuel air setup done and had to adjust the tps as well its running what seems nice now so ill have to wait for snow .. yea lol no snow in Edmonton on dec 31st is sad. But once i get it out make a few pulls with it ill see how things go. I had to rejet it cuz im not getting to the mountains this year so ill just be ditch banging and playin around at the gravel pit with it. Just happy its running good again thx
