Spare Ignition Key
ultimax
56
20
8
Washington State
I bought a used 2019 Alpha w/electric start from a private owner and he only had one ignition key for it. Does anyone know what is needed in order to get a spare key for the sled? We have no local Arctic Cat dealer so I thought this forum might be a place to start. Is there an easy way to bypass the ignition switch in case I lost the key? Any help would be appreciated. Thanks
IDspud
forum potato expert
4,118
Oakley, ID
Have bypassed key using simple wet weather push button rubber covered switch from Napa. Mounted it down by steering post so it can’t be accidentally pushed in.
Z
Jan 26, 2011
111
48
Pull the cover off of the key, there is a number on it. You can call any dealer to get you one. Country Cat would be a good place to start if you are in the States.
Octanee
1,188
218
Cranbrook Bc
I haven't looked closely but I'm pretty sure it's the same, you should be able to bypass it, there is no actual chip to the key...
ultimax
56
20
8
Washington State
Awesome,
Thanks for all the input. I guess my biggest concern was getting out of the mountains if the key gets lost while riding. It sounds like it's a non-issue since it will run by unplugging the hood harness. (y):)
