M
mezz250x
Im about ready to pull this sled into a hole and bury it.
1996 XCR 440
I bought it this summer at a swap meet and it ran kinda crumy, i figured it was cause it was 80° outside. Well were getting snow around here now so i have been working on it getting it ready. The problem is that it has terribly weak spark when pulling it over. Ive gotten it to start twice and rode it for a couple minutes each time, it runs awesome. But it is nearly imposible to get started cause of its pathetic spark(it wont even ignite starting fluid).
So far i have replaced the plugs, coil/cdi unit, and stator. Also tried un-hooking the key switch and voltage regulator. Still has crap spark. Should i replace the regulator too?(I have a donor sled for electrical parts). Also if this matters when it is idleing it idles fine, but will not pick up rpm unless i feather the throttle with full choke. With the choke off it dies no matter what. Is this maybe related to weak spark?
Someone please help me out here im not sure what to check or do next. Thanks in advance!
1996 XCR 440
