E line carbon pipe guards
Wrap works pretty good but you have to put it on right. The trick is you have to get the wrap wet first and wrap it on the pipe while wet. Remove the pipe to do this. This allows you to pull it really tight. Also make sure you wrap from the back of the bike to the front so that the overlapping wrap is shingled in the proper orientation and doesn't catch the snow. Use pipe clamps to hold it tight in strategic places. When the wrap is dry from the water, spray a whole can of silicone high temperature exhaust manifold spray paint. Maybe do 2-3 coats really saturating it. Let it dry thoroughly, then put it on your bike, make sure you're outside in a well vented area, light up your bike and let it cook (smoke) on. When its dry, it sets up like a cast.
If you don't want to wrap the pipe, E line makes carbon fiber header guards for stock headers as well as FMF megabombs. They are very long and cover the front of the header where it comes out of the engine and along the side by the kick starter. Check them out online to see what I'm talking about.
