SO MAD! 17 PRO RMK AXYS 800 SEIZED.
Nov 19, 2014
9
1
3
Looking for info, threads, help.....
- 1/31/19 I purchased a 2017 Pro Rmk Axys 800 155", 864 miles.
- Road 36 miles first weekend.
- Last Sat: warmed up properly, road 15 mins on/off throttle, great snow, etc..
- 30ish mph, throttle 1/4 - 1/2, maybe 2500-3k rpms
- NO CLANGING, NO KABOOM, NO LIGHTS, NO WARNING...….JUST SHUT DOWN.
- Pull cord will not pull - Primary will not budge, turn, move.....seized.
Any help, suggestion, experiences welcome...…
Dammit.
Gonzo
sledhed
1,752
435
83
Lolo, Montana
I would be mad too... sorry to hear that!
Any warranty left? Call your friendly local dealer with your VIN and find out.
Even if it has run out, Polaris *might* do a "goodwill" fix depending on circumstances... sled must be stock basically (exhaust etc.), so put stock pipe / can back on it and swing by your friendly local dealer for a "diagnosis" and you might get lucky...
Pull plugs and see if there is any aluminum on them etc. for starters.
  • Like
Reactions: SCAFONE and mtncat1
D
Drewd
687
378
Colorado
www.imnotrightinthehead.com
I'd pull plugs and check cylinders and possibly use a wooden dowel with a little persuasion to see if you can get the engine to rotate.
I've also had had starter assembly pawl break and cause similar problem in the past.
Good luck in sorting things out.
  • Like
Reactions: SCAFONE
Dec 28, 2018
147
108
Washington
Its not common for the 800's to lock up like that... maby the old owner dumped in a river or something... strange to buy it and just lock up... but its prob under warrenty still...
sledhed
1,752
435
83
Lolo, Montana
So I've heard about the un-common-ness. Somebody's gotta get lucky.
So, what was the results once you opened it up? And/or was it still under warranty (dealer can check by VIN), or possibly a goodwill fix (if your dealer can get them to do it)?
D
May 24, 2012
277
96
Start with checking the oil lines to make sure nothing obvious with the oil delivery. Before rushing to disassemble the engine for a peak at the pistons which normally doesn't provide a definite root cause, take the time to leak test the engine for the crank seals and head o-rings. A head leak is tough to find when the engine isn't running, so it takes special effort.
kanedog
Undefeated mountain clutching champ of the world.
3,116
3,917
Ya, you better do a leakdown test or Dan will lose his chit again.
Sent from my SM-G920W8 using Tapatalk
