So I wanna hear what you guys are running for fuel pressures!!
SLEDIOT
So Im runnin an 09 m1000 with a few trinkets. So I just turned my fuel pressure down to 36psi. I think it was 46 from the factory. What a f****** difference that made!! I still never made any temps over 1150 degrees. What are you guys running for psi on your 1000's? Cheers for beers
Mine is 45 psi. SLP did their set up #s for the Boondocker Box at 44 psi. Why turn it down that far instead of adjusting with the controller?:confused:
JUST ASKING.
Im running a D&D y-pipe, pipe and can and have my pure logic box set at zero. and can still pull fuel pressure. I watch my egts more than most watch ****. The sled ran like a thief in church so I must have done something right!!
Good luck with that. I wouldn't run it down past 42.
Thunder
I'm at 42 with full SLP exhaust system and Timbersled intake. That's where Attitude Industries tests from.
Aaron
Have you checked your plugs and pistons with the egts?
I run full slp pipe and bdx intake with oil delete. 51-53psi and go as high as 18+ with the bd box, the egts where 1150 wot stock and thats how it likes to be ran.
Have you ever heard of any performance setup on cars or anything else that requires less fuel pressure. usually they require high pressure injectors and a increase in F/P. To me your lowering atomization and getting close to your injectors slobbering. I would like to see how your sled runs compared to mine.
what is your ideal rpm for the d&d setup
