I haven't heard much about the velocity shocks that came on some of the Timbersleds. How are they working out? Better than the old LE shocks?
Teal, I have been curious about this myself. My buddy just installed a riot with those shocks and asked me where I should set them. I don’t have any idea. What would you recommend? On the QS-3’s that I have I pretty much go back-and-forth between “climb” mode and “wheelie” mode. Or as what I sometimes call fun mode, and more fun mode. I spend most of my time with the front shock on soft in the rear locked out. Especially early season when it’s deep and hollow like it has been here in Utah lately. Pretty much rides like an Aro 120.
Thanks fellows. Great place to start.I don't have a ton of time playing with settings on the velocity shocks. But for wheelie factor loosen up the slow speed compression on the rear, tighten it to keep the ski more planted.
I agree with everything sheetmetalfab posted.
I think you have that a little backwards. High speed compression (red outside knob) is for sharp, quick, undulating or what’s commonly called “square” bumps. Low speed compression (silver inside knob) is for landing a drop, or slower shock piston movements, such as loading the suspension in a corner or g outs.Velocity shocks on my axys work very well for adjusting to conditions.
Some general notes velocity shock specific.
Low speed compression adjustment (small inner knob) is your wheelie control on the rear shock. Loose = wheelie tight = climb
Front shock low speed soft climbs on top of powder.
Outer knob is bottom out control and big bump compliance.
Soft low speed compression soaks up chatter bumps all around.
