I made a transparent snowmobile trail map from trails GPS data. The map should overlay any other map you have on your Garmin GPS. Copy the file to your Garmin folder or if you have a Garmin\Maps\ folder on your GPS put it there. It should then show up in your map setting options. This displays much better than the older version I had from an imported PDF of the trails map.
I color coded groomed and ungroomed trails. Should be current except for the reroute of T trail on south end of the range
Click here to download
Snowies Map
I used this site that let's you upload your tracks data in .GPX format and covert it to a transparent map in .IMG format for your Garmin
www.javawa.nl
Snowies Map
JaVaWa | IMGfromGPX
Create your own maps based on GPX files for your GPS and for MapSource/BaseCamp on your computer.
![www.javawa.nl](https://javawa.nl/favicon.png)
