Snowmobile Helmet Lights?
27,612
Question, if you are using an Aux Helmet mounted light, which one are you running and Why?
Was out looking this morning and came across this.
ACTION LED LIGHTS
Gloworm XSV (G2.0) 3600 Lumen Light Set​
Gloworm’s most powerful light just got better (and brighter)!
The XSV (G2.0) leads the way with its 3600 lumen output, new features and unrivaled performance. The combination of Gloworm's brightest light and largest Power Pack ever creates a package that is hard to beat. Customization of the beam pattern and light output allow you to set up the Gloworm XSV(G2.0) to suit your desired runtime and trail conditions. Its relative small form factor and multiple mounting options give you the flexibility to setup the light how you need it most. The XSV will change the way you ride at night!
Specifications
  • 3600 lumen output (real, not theoretical)
  • Customizable with Gloworm LINK
  • 501g total light set weight
  • 3 optic system (2 x spot/1 x honeycomb)
  • Waterproof to IP67 – that’s really, really wet!
  • 2 hr. run time on MAX power
  • Wireless TX remote included
  • Power Pack 10 – 10000mAH fast charge battery* w/ power bank capability
  • 3 – CREE XHP 35.2 emitters
  • ~5 hour battery charge time w/ 20W charger
  • OLED Power Pack display
  • Overheat protection
    *G1.0 and G2.0 remotes and batteries are not interchangeable
Power Pack
Gloworm's newly redesigned battery - Power Pack - is a giant step forward in capacity, usability and performance. With a capacity 5000mAH or 10,000mAH, Power Pack extends your run time further than before, so you can keep on pedalling even longer. The sleek polycarbonate outer shell sits neatly against your bike frame or in your hydration pack. The single USB-C port gives you easy charging capability with the supplied Gloworm USB 20W charger (45W fast charger is available), as well as providing power bank options when you need to top up your phone, GPS or other electronics. And the OLED display keeps you in the know, monitoring battery levels and expected run time. And integrated silicone frame bumpers on Power Pack protect your precious frame.
Capacity
Power Pack 5 – 5000mAH @ 8.4v
Power Pack 10 – 10000mAH @ 8.4v
Charge Times – from 0%
Power Pack 5 Gloworm 20W Charger – 2 hrs 40min; Gloworm 45W Charger – 1hr 45min
Power Pack 10 Gloworm 20W Charger – 5hrs 15min; Gloworm 45W Charger – 3hr 30min
27,612
I have this one from oxbow, it looks similar to that one. It is small and bright, works well when needed.
Yup, they look VERY similar indeed!
Sheetmetalfab
7,957
6,715
Significantly brighter than the oxbow light.
05rmksteve
2,486
1,631
Brainerd, MN
I run an oxbow light. Great light and great customer service. Super bright for only being 2 leds.
Picture of my youngest daughter using the Oxbow light after her head light went out on her 120.
Put it on a golf cart this summer also.
#Oxbow gear.
