W
2016 Timbersled ST installed on a 2015 KTM 500 XCW
Includes:
KTM Powerparts Soft Seat - Mandatory when you sit down to ride all day
E-Line Pipe Gaurd - Prevents burning your expensive snow pants
AME Heated Grips - Keeps your fingers toasty on the coldest of days
Acerbis Skid Plate - Helps keep the motor warm
3.3 Gallon Spare Fuel Can - Sometimes "Anywhere you want to go" is a long way from the truck!
Power Sports Tech Velocity Intake System - Reduces weight and works in all snow conditions
Custom, widened, stomp thru Footpegs - No snow build-up = solid platform to stand on
5.1n Fork Springs - Stiffer suspension is mandatory for proper handling & performance
Left Side Radiator Delete Kit - Saves weight and helps maintain proper engine temps
Timbersled Chain Slider Update Kit along w/ warranty update chains - Replaced junk oem chains
Shorai high performance, lightweight Battery - Better cold weather cranking performance
Electric Start (worth its weight in gold on a snowbike) w/ Kick Start Back-up just in case
140 Miles / 6.8 Hrs on dirt- Just enough for proper break in - then the Timbersled Kit was installed.
Used for 8-10 rides last season then stored indoors. Oil changed after every ride. Comes with all components to switch back to dirt.
Suspension and handling completely dialed for optimum comfort and performance.
As you can see - this thing is in immaculate shape and set-up for tons of fun this winter & beyond!
$13,500 Located in Bozeman, Mt - Delivery negotiable
![IMG_7771.jpg IMG_7771.jpg](https://www.snowest.com/forum/data/attachments/228/228123-6de2c5dac9ddba78e9f189ec195d66ac.jpg)
Includes:
![IMG_7758.jpg IMG_7758.jpg](https://www.snowest.com/forum/data/attachments/228/228082-70af70d3e06fe19f76e26b9df33bab70.jpg)
![IMG_7761.jpg IMG_7761.jpg](https://www.snowest.com/forum/data/attachments/228/228092-3bccd311e6dd2a31d390c7d6d67e7250.jpg)
![IMG_7766.jpg IMG_7766.jpg](https://www.snowest.com/forum/data/attachments/228/228102-633bc7f5f8d0e13bddf4426ac135d1a8.jpg)
![IMG_7768.jpg IMG_7768.jpg](https://www.snowest.com/forum/data/attachments/228/228109-01ee02dd088f0c59d096d8c60cd49af6.jpg)
![IMG_7769.jpg IMG_7769.jpg](https://www.snowest.com/forum/data/attachments/228/228116-ce370cd0f5907c74896541faf1dfa848.jpg)
