Snow getting on clutch
shaun3232
My girls 09 600 iq shift is getting tons of snow on the clutches from the gap I have pictured.. I put some foam strips there.. Is there anything else to keep the snow from going in there.. Thanks
I would just use some hood straps there also which will secure the hood down in that spot to stop the snow from entering. Just cut some slits in the hood and use Polaris hood straps. Easy and cheap to come by.. I have seen this done many times in the same place.. uploadfromtaptalk1417409989578.jpg
The hood on my 06 chassis did this same thing, on both sides. Granted, mine has the 09 body update, but either way the problem is a sagging hinge up front. I did some tweaking to the bumper and hinge mount with a BFH and pry bar, now my hood shuts right.
Sent From God Knows Where...
The bumper and hinge is all plastic on this.. Everything is tight and closed like it should.. There's just a huge gap on both sides on this model ..
Truck topper seals the weather resistant type..come in varying heights/thickness.
Yea that's what I was thinking .. Wasn't sure if some made something for it.. I'll just use that stuff . Thanks
Automotive self adhesive bubble seal from NAPA is what we used on the IQ. Worked great. You can get it ACE Hardware also.
