smashed up 900
F
f15ejedi
I brought my sled back from my friend's cabin this weekend and discovered the damage may be worse than I thought. It looks like the tub where the lower a-arm mounts may be bent/tweaked but I'm not absolutely sure. Is there a way I can check this? Could I take measurements from the other side and compare them? Anyway I will be needing a lower a-arm and shock for the right side. Also I pulled the sway bar without upgrading my shocks and I think this had a lot to do with the instability of my front end. I also lost a ski rubber so that ski was dangling in the snow when I was climbing and I'm sure that is what cause me to hit a rock/stump/tree when the carnage occured. I'll post pictures tomorrow.
Post up some pix.... Tilt the sled on its side and take some pix that way.
Also, if you pull the swaybar on the 2005's, you should put the nuts and washers back on the studs for the sway bar mounts (4 of them)... they also help to hold the sheet metal of the bulkhead together.
Ouch...Sorry to hear that and those pesky ski rubbers are a ***** when they disappear on ya.....any pics?
Couldn't tip it on its side because its up against the house. I left everything installed when I pulled the swaybar. I don't think anything is bent. MH I got you PM. I've never lost a ski rubber before, has quite an affect on the position of the ski when the front end is off the ground! that thing dangles solow you can't see it. Such a cheap part to replace too! Live and learn.
Ouch!!!
I have a stock shock that I will give you, its off a 06 700....you just pay for shipping. I broke one early in the season and put Fox Zero Pro's on, its been sitting in a box ever since.
I have A arms too, but not free. :face-icon-small-hap
Let me know on the shock.
Ouch!!!
Yeah it hurt taking the handlebars in the chest for the 3rd time that day. I'm real interested in the shock. What do you figure shipping to Alaska would be? Not in a big hurry though.
Whats your zip code?
I'll check.
Man that is why this place is tops! Free parts!! How is the search going,post what you need. Some of us may have what you need, IQ section also.
