slp pipe
If it is used they also probably have a map in it already. Would need to download software from website if disc is not with PCV.
It's pretty simple. Email me again to remind me as I will send you all the install instructions. I'm assuming you have the PCV software already?
A word of advice. Don't just Velcro the PCV to the oil tank like they say. 0% chance it will hold. I made a little ziptie harness and attachedine to the carbon fiber over structure
If you want I can simplify all the instructions or u as well. There is alot that is in there that unles u are building your own maps or installing the PCV on something else just does not apply
Ditto to that! I luckily caught mine quickly as it had fallen off the tank and was getting pummeled by the primary clutch.
I didn't even think of asking if the software is with it. Right now i still have the program from my 2009 on my computer. Don't know if it is the same.
So I got the pipe and everything went together real good. Sounds and runs great except three times on my test ride ditch banging it would pop when I let off and hit about 3/4 throttle, didnt see any det light. I ran the record and couldn't make it do it but it did hit 8450 rpm once.
