Slp pipe?
F
firecatguy
Hey you guy who have put the SLP y-pipe,pipe and can on can you tell me is your power valve cable that close to your pipe?
yeah
I put heat tape on my oil resevoir. My first one melted and got a big warp in it. I got side vents,amp gauge cage, and two vents in both shock towers. Heat rises, so the gauge cage is like a chimney. Tim.
Get a hood lift from RKT for like 35.00 so the pipe does not melt the intake plenum. My powervalve cable also hits on the pipe.
I added the AMP Gauge thing this season..
Have side vents!!!so Im hoping this will take care any high temps?
They have tabs that you put the windshield rivets through and velcro on the back that attaches to the hood.
Mine is the same,
Whats the double springs ?
kept breaking them last year? not sure why...so last year I added 2 to the top two...no issue after that----BUT I just seen in SLP set up the say don't do that so I'm going to do a little research on the subject!!ANY IDEAS-----GOOD|BAD???
Kind of looks like they are stretched out a little to much. Maybe adjust the pipe -y tabs to get the spring tension less. ( Bend them)
I just asked becuse I have never seen that except on the turbos :)
