SLP pipe with GGB can
I am sure it will work. SLP recommends their can with their pipe but it is the pipe that makes HP and the can that muffles. I have a GGB can on my stock pipe with no issues. They are flow tested so they flow the same as stock.
absolutely not true to being able to run a different can with their pipe, been thru this just not long ago, talked to slp them selves, the restriction is done in there cans to create the power,i had to buy a special can for the pipe set directly from slp to make my pro run correctly, ran very dirty and boggy with the mbrp can on their pipe..
Absolutely not .. I ran a Unit 6 can on SLP pipe and is couldn't pull less weight than stock .. switched can to stock and gained it all back
Ordered the correct Can and started back with their clutching and was spot on from that day !!!
Another thing to remember SLP does make changes to there pipes , make sure you get the exact one for your YEAR !! Had a 13 with a 14-15 pipe and ran terrible , exchanged (Sold and bought another) and ran spotless!
