Putting Slp pipes on two 17 axys, Looking for input on clutching. Is Slp clutching working or should I just put Polaris weights in it, 8-11,000 elevation thanks for the input.
66 gram EPISODE Belly Busters with Carl's helix. Stock springs. Works like a charm. Make sure your weights are weighed and balanced out if necessary. Mine did not need to be balanced. It is easy to check before installation.
I ran mine in the 42 last year. it worked pretty good but I switched to the 40 for this season. Several of my friends ran theirs in the 40. The sled seemed happier and snappier in that ramp. !0,000' is pushing it for 66 gram weights although I did have mine at or near that altitude once last year. It worked OK but I would definitely go with more shallow ramp (40) with the Carl's helix.
