SLP MTX weight users
rags319
Are the MTX adjustable weights worth using on the pro. Did you have to reshim clutch-to-shive distance. Could use alittle more rpm. Don't know if this would be the right thing to try or not.
I ride 8500-10000ft. Running 10-60s now.
I ride 6-9000 ft. I use 65 gram MTX and slp blue/pink in the primary, no shims needed. The secondary has the blk/purple spring and 2 delrins. I pull 8200-8300. I need to add a gram.
