Im struggling to get peak rpm and looking for some input. the two kits are the same except carls sells you there clutching and slp sells you theres. also carls includes the Bully Dog tuner for above 5k feet. I bought my setup from carls, got there kit for 6-8k feet elevation and it came with Bully Dog tuner with Carls custom tune. Im running Carls clutching with 62-42.40/60-40.40 helix and stock secondary spring with the roller bearing. primary is stock spring with EPI 66gram weights. Both springs are new, and belt only has 1-200 miles on it. SLP recommends 83-8450rpm for there pipes power....I don't see over 8100. On flat ground if I hold it WFO for long enough it will climb to 8200. Track speed while climbing really isn't anything to brag about either....only about 34-36 mph. Seems kinda silly to throw the 64gram stock weights back in it just to get rpm since completely bone stock machine will spin the 64s to 8150-8200??? just doesn't seem like much gain for $2000![Face Icon Small Disgusted :face-icon-small-dis :face-icon-small-dis](/forum/images/smilies/old/face-icon-small-disgusted.gif)
What are you guys setups with these kits, and what are you seeing for rpm? track speed?
My sled is a 2017 Axys 800 155 2.6 with stock belt drive gearing. running 91 non-ethanol fuel with ECU set for that. Have just under 1k miles on machine, stage 3 kit was new this yr. Belt deflection is good, clutches all cleaned, track tension correct
sorry for kinda long post but wanted to get as much setup, and sled information as possible up front.
