On more thing Kraven, are you able to adjust the engine bolts with everything hooked up and bolted down? Just looks a little bit tight under there?? Thanks for your help.
Do you mean the bolts under the engine?
If so, No you can't get at them when it's bolted down.
Here' how I do it:
If you use the SLP style tool and measure the EXACT air gap at the REAR of the secondary, let's say .140" ,
slot the holes slightly less than double that air gap amount
.140" x 2 = .280"
Slot both holes on the mag side
going forward .250" and you'll be real close on your first try.
To re-adjust, you'll need to remove and re-do.
We did one 2007 DRAGON 700 leaving the engine in, ALL hoses, wires, fuel lines, EVERYTHING hooked up. Took 2 1/2 hours start to finish, not rushing.
Removed the pipe and 4 engine mounts, jacked up the engine and propped wood blocks under it, it was A P.I.T.A. but we were able to remove the MAG SIDE engine bracket, slot it and replace it.
Remember, when tightening the engine bracket, push the MAG SIDE bracket towards the
REAR of the sled before tightening the engine bolts.
Hope this helps, get the SLP / or H.P.E. style tool, (DO NOT USE the POLARIS tool as it has .070" to .075" of "kick" built into it) post a pic, any other ?? be glad to help you out
