Some information for anyone out there who is looking to boost a yz450f on the cheap.
2014 Yamaha Yz450f
HotCams Stage 1 intake and exhaust (bottom end less valve overlap)
Port and polished cylinder heads with a fresh valve job
Milled head to increase compression ration
Gytr High compression piston oil squirter
Athena Race gasket set
Parts List:
PCV
At-200
Pod-300
Map sensor 5S6727 (2002 Civic 1.7) good for 8.7 Psi (plugs direct into harness)
Garret GT1446V (from a Chevrolet Cruze 1.4L) built in BOV and oil restrictor
2" universal intercooler pipe kit
2"x1.5" silicone coupling
36" 3/8" dia 1/8npt x -4(an) oil feed line
30" 1/2" high heat hose
38mm v-band external waste gate
2x 3/8npt x 1/2" barb fittings
2x 5/8" mechanical clamps
Universal 2" pod intake with outerwear cover
10' exhaust wrap
10' heat resistant wrap
10' of 1/8" vacuum line
2601 U-J Mandrel Bend pipe, 1.5" O.D.
Universal Motorcycle exhaust
A lot of the items were already in my possession but if anyone were to purchase all these items it would sum down to $1600USD including the price of a turbo (450$)
Sensors
Stock Yamaha Map sensors range was 20inHG(1.34Volts) to 4Psi (4.4Volts)
Map sensor 5S6727(2002 honda civic)range is 20inHG(0.828Volts) to 8.7Psi(4.4Volts)
Turbo/Oil
The turbo sounds small but the turbine allows a 1.4L engine to breath at high rpm
It is casted specific so i had to modify the housing to accept flanges and i deleted the internal waste gate due to space issues. Tapped the turbo to accept my new fittings.
I used the oil check bolt on the front of the head(intake side) i originally machined a fitting to fit the stock threads but i didn't have much faith so i drill and tapped the yz head for 1/8NPT.
Drilled the magneto cover to accept 3/8"Npt to accept a 90* elbow and barbed fitting for the oil drain.
Fuel
Running 100LL Aviation fuel 1.80$ Cad a liter
So Far the stock injector has reached a max of 85% of its duty cycle at 4.8psi at 10.7 afr at 10300rpm. going to push till i get 100% at 11.5afr and log in its max boost/rpm/afr then I'm going to Decap the injector to increase its pounds per hour. (https://sites.google.com/site/sloppywiki/how-to-section/decap-factory-fuel-injectors)
Tuning
As of right now I'm using the pod-300 to Datalog and letting the auto tune do up to 20% of the enrichment and enleanments, I will post my tune file or photos for anyone in the future. (when its done)
Future/ upcoming mods
3 Bar map Sensor
Electronic boost controller
Head studs
matching a Headshim to lower c/r
2014 Yamaha Yz450f
Parts List:
PCV
At-200
Pod-300
10' exhaust wrap
Sensors
Turbo/Oil
Fuel
Tuning
3 Bar map Sensor
Head studs
