Slightly modded M1000 runnin dead even with a stock M7!!!!!!
My 07 m1000 has an intake, y-pipe, can, v-force3s, and a fuel regulator. My buddies sled is an 05 m7 with nothing but an intake and we run pretty much dead even on a climb both with 153 a20 tracks and 07 skids. We ride at 6-8 thousand feet im still running stock clutching and im sure that has somethin to do with it........ Im looking for some clutching advice since im pretty much clueless when it comes to clutching. Just wonderin what you guys would try?????
If you are running the A20 in powder mode I would say traction is the limiting factor. Power means nothing if you cant put it to the ground. As for clutching, if your peak rpm is in the 7200-7400 range you should be running circles around the 7.
