B
Traditional Scratchers: The rigid metal design of a traditional scratcher, significantly reduces their durability. Numerous common and every day obstacles can easily break or bend traditional scratchers. Rocks, stumps, roads, bridges, trailers, all can catch and break scratchers in an instant. In addition, they do not have replaceable wear points, so as scratchers are used and worn down, they must be replaced in their entirety. Often at least a $50 investment.
SLIDEKICKS: The flexible design of the SLIDEKICKS allow them to flex and bend as needed to safely cross stumps, rocks, and man made objects without damage. Where a traditional scratcher is fixed in one position, the SLIDEKICKS can bent to any angle caused by unexpected objects. SLIDEKICKS also have replaceable wear points. So instead of replacing an entire set of scratchers, you can purchase our inexpensive wear points and replace them as needed. SLIDEKICKS are an investment that will save you money over the long term.
You can purchase them on:
www.icescratcher.com
Thanks for looking!
Thanks for looking!
