Ok, a week ago my sled wouldn't start and I THINK the fuel pickups were clogged. Now it wont start again.
It ran fine all day yesterday and I parked it in the garage with about an inch and half of fuel. It wouldn't start this morning. Not even fire. So then I did the reverse the fuel pump trick to clean the pickups out again. Then I ran it forward and nothing. Figuring I didn't have enough fuel I manually ran the pump some more and flooded it. At this point I had good spark, all the time. It would occasionally fire and run for a few seconds and then shut down. This went on for a few hours while I has trying to clean it out. I got 4 new plugs and same thing. When the plugs are dry it would fire. Then I disconnected the fuel pump and it started up and ran for about 7 seconds. Figuring that I cleaned the cases of the fuel, I connected the fuel pump and then NOTHING. It hasn't fired since then and I just gave up for the day. Right before I quit I checked the spark AGAIN and it wasn't sparking for about 5 pulls and then it sparked for a few pulls and then no spark for a pull and so on. I also noticed that throughout the day when I pull it over the check engine light is on and the oil light is on. I have full oil. And now the check engine light is NOT on.
I've been dicking around with this thing for over 5 hours today and I'm at a loss.
I JUST put a new coil on a few days ago and it has one ride on it since then.
Thoughts?
Thoughts?
