Is there a reason my 2012 600 switch wont start right now. It floods. I unplug fuelpump and itll fire up for short time then run out of fuel. Plug in pump and itll fire up for a second then die. It floods out. Too warm out? 25C
Itll literally run for 2 seconds then die. Plugs are wet. Unplug pump and itll eventually run for another 2 seconds. Any throttle and it won't run. Like tps sensor or injectors. I guess I could check fuel pressure too. It ran a month ago just not now.
New set of champs and new set of ngk. Thinkin its time to send it in to get scoped.
Good spark. I can get it to run and as soon as I plug in the pump itll die and plugs are wet.
Fuel didnt smell bad but I added some av gas to top up octane after I had troubles. I was leaning toward injectors. Ethanol is the devil. Not easy to get non ethanol fuel around here.
By bad injector what do you guys mean?
As far as ethanol ive had issues with my mx bikes and had ethanol partially clog injectors. It just wouldn't get enough fuel and run odd, like the choke was on but there is no choke. On them (Suzuki rmzs) you simply pull the injector out, hook it up to a 12volt power source To get the injector to open and blow them our with compressed air and your clean again.
