Longer shocks or shorter radius rods.
I do like the narrow stance as well, after riding my pro a lot the edge just feels better to be with the stance set as narrow as possible, I shortened the radius rods until the trailing arms almost were touching the body. Next step was trying to get more travel so I went with the zbros remote reservoir shocks ,they are 19" extended with 7 inches of stroke. Using a soft 1st stage spring they collaspe a bit when installed but have very quick extention so skis stay planted on trail. This setup allows for very easy "rollover" to side hill like adream. I also found the slp powder pro with carls cut to be the ticket. Probably raised the front end aprox 2 inches.
This raise works very well being that I run the avid chaincase,I set the case 1" lower when installing it as well (major deal as jackshaft now in tunnel area) but it works very very well. Dropped skid hole 1.5 inches from stock and allows up to 3" paddle track.
I tried the 3" x16 track and went back to the 2.5 x15 just worked a whole bunch better.
Another thing I did to help side hilling was to move the rear idlers inside the rails like a newed sled, this combined with the front works very very well for me.
Cut the radius rods 1/2". You wil need a tap to make the threads deeper. (Dont remember the size.)witch one will be easier and how long and how hard to do both
