Dual carbide on the stockers, can't beat them.
Do you have a picture??
I had the gen II on my apex and went back to the stock skis but added a set of dual carbides. I was much happier with this set up.
I don't have any pictures of them. Climbmax told me to try them, they get rid of the darting on the trail and when the snow is crusty. They are a yamaha part, so your local dealer should be able to get them for you.
>>>I used VK skis for the last 3 seasons on the TRX1 much better in crusty snow than stock all in all very forgiving and floats well.
I did get the simons gen 2 to try out but will go back to the VK skis in a hart-beat if I don't like them.
By the way the VK'S work awesome for backing up as well.
The VK ski takes the same carbides ski loop and rubber stops that came on the 04 RX1, You need the little base-plate that goes under the rubber stop and the spacers to Adjust the ski stance are a bit different so you need them.
It is a straight ski no fuss with a relatively deep keel and a good kick up in the back for easy backing up. The Keel looks a bid wider and it has less rocker than the mountain ski.
It had much better manners than the Mountain ski noting wild and wonderful, just does the job and well in all conditions and floats better in the pow too.
It should also accommodate the dual carbides if you so desire.
The cheapest most durable ski you can get.
I will give a update on the gen 2s as soon as I get out 5 feet of pow just 1.5 hrs south of here.
