Skinz headlight delete
R
Rmk_RDR
I ordered a skinz headlight for my pro from Rogur Motorsports and I thought I was getting the delete that was all vented like the picture in the description showed but I got the other delete that has little venting and im wondering if the one I got is better or the totally vented one is better? I need answers because I might just drill more holes in the one I got now for more venting. I noticed the one I got is riveted in and the totally vented one looks like it gets glued in?
Vented one
http://www.roguemotorsportz.com/static/product_images/zoom/24103695.jpg
The one I got
http://www.ebay.com/itm/like/370893524958?lpid=82
I run the rivet one from skinz. It's got plenty of venting an no need to dril out more holes. Combo with the wrp gauge lifter and you will have lots of air flow through there.
http://www.roguemotorsportz.com/static/product_images/zoom/24103695.jpg vented one
http://www.ebay.com/itm/like/370893524958?lpid=82the one I got
That first pic was there prototype delete, the one in the eBay link is what they settled on. And no don't drill any more holes it works fine the way it is.
Mountain Fit Hoods delete with Rigid Industries SR-M2 in driving pattern. Light from Blown Motor, delete from Mountain Fit Hoods with Bill's direct wiring harness that plugs into factory headlight plug, also has built in rectifier. Thinking of adding a second one for other side, but with helmet mount Halo 800, I think I have plenty of light. The helmet mount is a Rigid Industries HALO 800 from Blown Motor. Puts out 800 Lumens. This thing is bright, 1000' beam. Light on sled and light on helmet pointing wherever you look, best of both worlds, helmet light attaches to a GoPro mount. You could mount to sled also, keep light in pack till needed.
Did you make the helmet mount for the flashlight?
The mount on the helmet is a GoPro base, I did adapt a clamp to fit the light to a GoPro mount. The pictured clamp is one of the first tried, not stiff enough. The new clamps that are arriving will be the finished product and much stronger. Contact Shane at Blown Motor if interested
Pray for SNOW!
