Here is 670 big bore to a 740. It's a 1998 case. Had seadooclinc mod case for better oiling. New crankshaft with all new bearing and has fat bearing kit and welded all done by seadooclinc. Cylinders have new sleeves by advanced sleeve and new WSM seadoo 720 platinum coated pistons. Has been tunnel ported and a unionbay rotary valve cover tunnel ported to match, rotary valve area resurfaced and new rave valve blades that where cut to fit the 740 all that done by crankshop. Also a new carbon tech rotary valve 163 degree and excellent 40mm carbs. The head has cheater domes done by RKT, they are for pump gas and 6000ft to 9000ft. He can make new ones for lower elevation for 100.00 each. New stator and comes with coil and hot wires. It is wired for 1997 ignition, which can be easily changed. Has all recoil parts I just didn't get pics of them, no clutch or pipes. I was planning to put this motor in too my 1997 stock 670 summit but i ended up sell it and I don't have another sled to put this in. The motor will be all assemble and torqued to spec. when I ship it. If you have any questions let me know
New price 1600.00 plus shipping
call 208-390-5715
http://www.flickr.com/photos/31466397@N02/
call 208-390-5715
