i am having troubles getting my skid out? can't see to get all four bolts out
I think he's probably talking about trying to get the second out after the first because the inner sleeve just rotates. Work them out as close to the same rate on each bolt as you can. Once both only have a couple threads left they will come out...
I have done this in the past
1. Remove one bolt
2. Install a longer bolt with a jam nut, tighten down the jam nut
3. Remove the opposite side
4. Back off the jam nut
5. Remove the longer bolt
