sledheadjake
what is the easiest way to remove the rear skid on a sled.so it is easy to put back in?any info helpful. thanks
i find instead of risking major injury with releasing the torsion springs i take a ratchet strap and wrap it around where the top of the rear shock mounts and then where the bottom mounts, put some tension on it. then when you put the skid back in put in the front bolts first and the back ones will line right up!!!
This is actually a good question.
I have pulled my skid out countless times over the years on various sleds.
Getting the front bolts out at times can be a real pain in the butt.......
You loosen one side, then when you go to the other side and loosen that side up, the bolt just spins on the axle, so you then have to go and retighten the other side until you get the previous side loose, then loosen both so they will come out. YOu will understand once you try it........ It is a retarded design, and one that has stuck with the industry for decades.
Getting the skid back in: If you just attempt to put the thing back in without compressing the skid, the rear holes will never line up. You have to compress the skid a bit to get the holes to line up. There are a few methods to do this. 1. There is a skid compression tool you can buy (Not worth it in my opinion) 2. Cheap old ratchet strap.
Take the ratchet strap and put it over the top "axle" where the rear bolts up. Put one of the "S" hooks on the lower skid, same with the other.
Put both of the front skid bolts on, then rotate the skid towards the mounting holes and keep ratcheting until the holes line up. Install bolts, life is good
Put the sled on its side when you are doing all of this.
Get a buddy and a case of beer, both will help you get this job done........
