skid plate
I pick up an after market skid plate. It has 8 holes in it, it comes with rivets. do you have to drip the holes out in the bellypan?
Sled: 12 pro rmk 800 163
Thanks for info
Jerry
U should be able to put the belly pan up the sled and you will see the 2 rivets that you have to drill out that are already on the sled. Drill those out first and instal the two. Then push that belly pan tight to the sled and drill through the belly pan and your sled where the holes are marked. should be easy. Use a 3/16 drill bit. and be sure to use the right rivets in the right holes.
thanks
