Sly dogs pure stock w/7/16 bolt weighed 6.45 lbs. Once modded like grinding down the round runner into a teardrop triangle and cutting studs down to fit low profile lock nuts. Replacing steel bushings with aluminum and running 3/8 custom bolt including aluminum spindle bushing weighed 5.34 lbs. Just think all that work for a little over 2 lbs! I must be nuts!
Mike
oh wow, that sounds awesome, now if only more people could find out weights of the skis, and of course without snow on them
i'm curious about the zx skis
ZX Skis, ya mean newer skidoo XP right? Pilot 6.9? Toying with the idea of putting them on your Polaris? I put a set of 6.9 on my 07 RMK for the last ride, definitely turned better, easy to mount. More info if needed, if that is where you are headed.....
