Ski tilded
wonderxc600
I hit a rock hard last year and bent my lower a-arm, so I got new a-arms top and bottom /went to alternative impact a-arms on both side and switched back to original spindles "I had off set spindils on when this happened" and my ski is still tilded/inside is higher than the outside. Any help would be greatly appreciated.
i just put the same set on mine ,make sure the lower ball joint has a 1/2 inch of thread in front of the nut . no threads showing in front of the nut on the upper joint
i just looked at the pic closer . the jam nuts are both missing and the lower joint is in way too far , like i said above ,put the jam nuts in the joints then the top joint should have no threads showing,and the lower 1/2 inches of thread showing
Well that could be part of the issue on the lower then, because I tightened it all the way, but why would the other side look normal. Just curious and thanks for the heads up.
