ski lift with new shocks
hi all,
sorry if you have seen me post alot about the fox shocks on a pro but im new to the air shock game. i did a search and couldnt find much, so now im asking all the poo brothers out there.
i have a 14' pro 155" and just installed fox float evols on the skis with stock WE in skid, they ride nice but i noticed more ski lift than the stock shocks while on the trail to get to the mountains. what would be a good starting point for some adjustments to help with the unwanted lift?
current settings are;
sway bar is attached
rebound- 7 clicks
evol chamber- 160psi
main chamber- 60psi
riding weight- 235lb.
thanks!!!!!!
I would contact Chris Kasel, the parts and performance manager at Carl's Cycle Sales in Boise ID. He can give you all kinds of setup info that will help. 208-853-5550.
If you are indeed getting ski lift. That is controlled entirely by your rear suspension settings and has zero or near zero to do with your new front shocks.
The previous posters recommendation is probably a good start, as I won't run those pogo stick style shocks.
The OP could be referring to ski lift in the corners, which would be attributed, in part, by front shock setup.
I agree with the suggestion to call Chris.
