parting out my 2007 summit 800r xrs.
159" rear suspension complete with SLP hyfax's $500.00
SLP billet head domes are for 6000' plus has 4 rides on it $250.00
steering post $75.00
upper a-arms $40.00 each
lower left a-arm $75.00
spindles they have been polished $50.00 each
tie rods with rod ends and they are polished as well $30.00 each
engine cases great shape with no damage $600.00
mono block cylinder great shape $500.00
stock head $125.00
water pump/oil pump shaft $125.00
stater $200.00
engine mount plate $100.00
flywheel $100.00
trigger coils $50.00 each
rave solenoids $50.00 each
rave vales $100.00 each
wiring harness $75.00
chain case with cover $150.00
mpem/ecu/cdi box with dess key $250.00
tachometer with small digital speedometer $100.00
complete engine bolt kit $50.00
v force 3 reeds $150.00
8" black riser block $50.00
protaper fat bars with two bar pads $50.00
protaper fat bar clamp kit $40.00
brake caliper $60.00
extended brake line $50.00
brake master cylinder $80.00
jackshaft $125.00
oil pump $75.00
coolant tank $35.00
voltage regulatgor $45.00
ignition coil $35.00
secondary clutch $125.00
stock head $125.00
stater $200.00
flywheel $100.00
jackshaft $125.00
oil pump $75.00
coolant tank $35.00
