Ski doo parts for sale!
skank
Lots of ski-doo parts for sale. Please e-mail me with interests and questions. sim_aimone@hotmail.com
INTAKE & FUEL PARTS
Stock reed assemblies with spacers (perfect shape, very low miles) - $150
2-K&N filter pods. Large round & angled up with socks (barely used) - $75
2-Kickass filter pods with socks (some wear but still work well) - $50
2002-vforce reed carb boots (boots only) - $40
2004 dual outlet skidoo fuel pump - $35
2004 factory mod 800 carbs, taper bored. $150
2- 2004 mxzx 5 gallon fuel tanks - $30 each
ENGINE PARTS
2-800 Trygstad ported cylinders - $600 for the pair
05 engine support plate with mounts - $75
Oil pump cancel bottle assembly and pump block off plate (gasket and screws included) - $50
5 bottom end and crankcase assembly (all good shape other than one blued rod ) $??
2-rave valve assemblies (one valve has damage on gilotine) - $50 each
05 recoil assembly (used but still works fine) -$50
Team Industries 800 drive clutch adjustable arm kit complete with all the weight - $150
ELECTRICAL
05 summit computer mpem (programmed with no rev limiter and mod timing curve) - $250
05 summit stator - $100
05 summit flywheel - $100
05 summit flywheel pickup assembly - $40
05 air box sensor - $25
05 cylinder head temperature sensor - $25
04 speedometer and pod with wind deflectors - $125
TRACKS
136x15x1.75 factory skidoo lightweight hillcross track - $350
121x15x.75 track with 144 studboy chisel studs. (I used for grass draggs) - $350
WHEELS, RAILS, EXTENSIONS, AXLES, RISER
4 -8 inch wheels, mmp, black starfire with bearings. - $350
lots of bogie wheels and mounts available - $????
2 pairs of 121 440 mxzx rails for scIII skid. - $50 pair
2004 440 mxzx stock handlebar riser with clamps - $30
MMP skidoo rail extensions with off set axle. scIII 136-144, converts 6in wheel to 8in wheel. - $60
MMP skidoo freedom axle kit. 6-8in wheel conversion or 7-9in wheel conversion. - $75
MMP polaris rail extensions for 2000-2005 proX. 121-144 converts to 8in wheel. - $75
Tracks USA polaris rail extensions for 2000-2005 proX 121-144 - $75
