<iframe width="560" height="315" src="https://www.youtube.com/embed/4vJY04c2WRA" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Thanks for clarifying about the QS3 being a slow speed compression damping, haven't been able to find that info anywhere. I am looking at putting on new shocks on a brand new G4. I am new to both Skidoo and air shocks -for sledding, (I mountain bike as well), having only run coilers on an RMK before this.
Not to thread hijack, but I was wondering if the QS3 adjustment would help for adding heavy loads to the sled such as doubling up for sled skiing? Having read almost every post on these Fox shocks for the G4, what kind of fiddling around with the air pressures do you guys experience when compensating for altitude and cold? I am a fan of set and forget, but also intrigued by the adjustability of these air shocks.
Also very intrigued by Tom's E-motion...
Hey dude!
Some great questions...
I came into the sport from both mountain biking and skiing, so yeah, I totally sympathize to your situation.
Few thoughts...
1) QS3 is excellent for a sled ski application. I do think getting a custom QS3 setup (valved for what you are doing) will make a big difference. Tom is the only guy selling the torsion bar delete with an air spring, and for that use, yeah, its rad for sled skiing/hauling big loads. He also has the QSL (a lockout version of the QS3 - its just a firmer "3" position). Everyone knows I help him out, so I have bias here that I'm not hiding. But I also came to him as a customer first...
2) I set my pressures outside at 6,500 feet. Never mess with them. Yeah, they are a bit different at 10,000 feet, but I never notice. If I adjusted them in a warm garage, sure, it'd be different at 15 degrees. But so long as they are setup close to the temp/elevation, you'll never mess with them. They aren't hyper sensitive. They are less sensitive than your mountain bike (higher volume chamber)...that should tell you what you need to know.
Good to know. Yeah, I kinda picked up that you are biased towards Tom's stuff, but then again, it seems that everyone who has it is as well…
So to clarify, the QS3 on a higher setting will impact slow speed compression, meaning with a heavier weight it will act to raise the force required to react to body roll, almost acting like increasing sag? I know that last part about sag probably isn't the best way to describe it, I'm just trying to wrap my brain around what it will do.
With the Emotion skid, what would that QSL do for it/me?
How is the e-motoion better than Fox Doo shocks valved for me?
Thanks for your help. I've actually emailed and called a couple times and haven't heard back.
