Can someone explain the spring/weight relation in the primary clutch. If you have a stiffer spring does it give youore or less rpm is the primary.
And then the same thing in the driven/secondary if you have a heavier spring does it help with more rpms or take away. And also the relation of the spring and the helix.
Thanks in advance
Thanks in advance
