Silber
Let letting everyone know we are finishing up the final stages of our water/meth injection kits. We are going to offer this kit for our polaris raw chassis turbo kits. This kit will also work on any snowmobile. Just have to make your own mounts for the fuild tank. Water/meth is proportionally injecting according to boost pressure, with full adjustment of what psi to start the injection and psi for max injection. Here are some of the benefits of a water/meth kit for a turbcharged application:
Low cost, water/meth is cheaper than running race gas.
More Power, running water/meth lowers your charge temp, prevents detonation.
Clean, running water/meth is like steam cleaning your engine, you have very little carbon build up with this.
More effecient, your able to run leaner air fuel ratios, and advance the timing to create more power. And the ability to run more boost.
When Running water/meth with 91 pump fuel its comparable to running 110+ octane fuel. Depending on mixture ratio you can gain up to 25 points of octane.
Avalibity, methanol can be bought from most gas stations. Windshield washer fluid contains 30%. Also gas line anitfreeze.
The polaris kits can be fitted to any polaris raw chassis, with plug and play connections and a fitted fuild tank for this chassis.
Users can easily adapt this kit to any snowmobile.
Kits come with two nozzles to tune for your desired boost levels.
For more information, please pm, or email me at Justin_silber@hotmail.com
www.silberturbos.com
