SILBER TURBOS 2011 IQ CHASSIS TURBO KITS INFORMATION
Silber
Here is a list of what is included this year in our IQ chassis turbo kits. We have many new options and components this year to fit everyones needs. We have made this kit very complete with no need to purchase any extra parts. We will be posting pictures and videos of some of the new products, to better explain there purpose and function. Check out our website for more information and pricing. Please contact us with any questions or concerns.
Polaris Silber Turbo Kit
2008 - 2010 Polaris Turbo Kit (Dragon, Rmk, Iq’s Assaults, Switchbacks) 800’s 700’s 600’s
This Turbo kit will allow you to run boost levels from 7-18psi of boost. We offer a low 3 psi waste gate for user looking to run lower boost levels, this is perfect for low elevations and running pump gas. Hp ranges depends on altitude and boost level which can range from 160 hp to 250+ hp. This turbo kit has very minimal turbo lag when used with our recommended clutch kit. The kit has been updated from previous years with some great options including:
O ring fitted air box
Vented threaded oil filler cap
10000hr oil pump
Aluminum Oil cooler
Oil level sight tube
Oil Tank mount with roll over valve
Turbo coolant lines and fittings
Turbo Smart blow off valve
The turbo kit comes complete with all of these items. This turbo kit is complete, no need to purchase extras. This is one of the most advanced turbo kits on the market with these new features. Kits comes 90% pre assembled for easy installation.
Garrett Ball Bearing Turbocharger Gt2860rs
10000 hr oil pump pre wired
Precut and assembled oil lines and filter
Oil pressure gauge
Oil tank with vented filler cap and oil level sight tube
Aluminum Oil cooler
Oil tank mount with roll over valve
Turbo air filter screen and prefilter
Tunnel dump exhaust, with cutout template and pre welded o2 sensor bung
Aluminum Exhaust block off plate
Turbo inlet stinger pipe and flange
Stainless Turbo inlet gasket
2.25” Aluminum charge Tube
Turbo Smart blow off valve with fittings and lines
Silicone Couplers
T Bolt Clamps
Billet Aluminum boost controller
Turbo coolant lines
Fuel Pressure Regulator
Quick Connect fuel lines
Fuel Pressure Gauge
Attitude Fuel Controller
Aluminum Throttle Body Reinforcement Plate
Aluminum O ring fitted air box
Precut and assembled boost lines for FPR, Fuel control box, And boost Gauge
2 1/16th Boost Gauge
Aluminum Gauge Mount for handlebars
Extra exhaust springs
Zipties
All nuts, bolts, and washers
Rivets
Complete Installation Instructions
AEM Wideband O2 sensor gauge
Clutch Kit (Primary Spring, Secondary spring, Custom cut Team Helix, Adjustable weights.)
Shock Tower Vents, and Side Panel Vents
Will have pics and some videos posted soon of the new parts.
We also have intercoolers this year too, forgot to add that to the list.
Thanks
Justin Silbernagel
