Silber turbo no bottom end
Hey guys anyone have a cure for silber turbo with bully dog bottom end lack of jam and turbo lag? Mine is tough to ride in the trees from a dead stop or quik throttle application. Power is slow to come on. I also wonder if I'm pulling
7800 Rpm at wot, how much weight do I need to remove to get were I need to be.
Cheers
At least a couple grams. You can make it more revy with a different primary set up. Mine is very responsive, I have the pink just what Justin sent with the kit. I know a few guys who installed a lowe engaging spring and lost the throttle response.
bottom end
you might want to look into the mds turbo weights, I am running them with a pink spring, my engagement is a little higher than I would like but bottom end response is good
Thanks guys. I do have the pink spring just not happy with dead spot. Maybe less boost so I can run lighter weights in my primary?? Maybe that would help. Rite now I'm running 8 psi at around 3000 to 6000 feet in elevation
Take your primary clutch apart and inspect all the bushings and rollers. Also put a new 115 Polaris belt on it.
What will the belt do ? And rollers and all are good. Had it apart not long ago . Has a big at first but soon as rpms are increased and sleds moving it rips ??
If the belt sits to far down in the secondary clutch it will do the same as having higher gearing. Check your belt deflection and adjust as neccessay. Also make sure the primary spring isn't broken.
