P
I am having some bottom end bogging just after the clutch engages on my newly installed silber turbo on my 2016 axys. It feels like its loading up, but its happening when i have not been idling at all for long periods. I am currently on 100% 100LL to eliminate fuel related issues. Im at 10k ft and up runnin 5lbs boost. When installing the kit here's what i did.
Measured compression before and after a few rides. Both tests both cyls about 87psi at 10k ft which should be good. My gauge always reads a bit low as well.
Checked reeds. Good
New spark plugs
Cleaned ex valves without disconnecting
Pulled cylinder to measure pistons etc
New belt deflection set
Clutches cleaned thoroughly
No exhaust or intake leaks
My first ride did not have much noticeable bogging. i had all old 91 ethanol gas in. It was causing det so i switched to 100ll to isolate. Det is gone. I also added clutch weights hoping for smoother engagement. So. Either the ethanol created a hotter burn helping it to run cleaner on bottom, or it wants lower clutch weights.
Thoughts?
Checked reeds. Good
New spark plugs
Thoughts?
