Silber stainless braided lines
Coldestwinter1
I seen a picture today of a Silber setup with braided lines. How sweet is that last year I melted my oil supply line to the turbo and put on my list to track down or have custom lines made which would look nice and function. Does anyone know anything about this it could save me a ton of time.
they have some they are using on the G4 kits. Its just an extension that gets it away from the turbo then reduces to the soft line once away from the heat. call em up i bet you could buy one.
I used a double wrap of some thermal heat tape on mine. Just installed the turbo though - hoping it does the trick for the winter.
It will. This is what we've suggested in the past and it's worked great. Just not as clean looking as the braided lines.
I'd definitely check on it a few times on my first couple of rides. when send in the ecu I'ill ask about the braided lines and there's a company here that specializes on hoses and stuff I'll check them out too and update you guys on what I find out.
I had alot of grief with that stupid rubber hose. Always melting. Ordered braided line off summit racing i believe is where i got it. Ill take a picture of it later. Installed and never had an issue since
