Silber kit???
standup06
Dec 3, 2007
80
minnesota
Here are the numbers I have been running 6-10k elevation
Green 5
Yellow 3
Red 2.5
Green blue 4.5
Yellow blue 6.5
Red blue 7
Texasnowman
New member
18
2
3
Mobeetie Texas
My new Silber kit has no oil pump / tank They are using the oil from the intake ports Have not got installed yet or tested but will get some pics and some truth about the kit So far looks good
wwillf01
2,790
616
Heber Ut
wwillf01
2,790
616
Heber Ut
you do the install Yourself??? how bad was it??
I have to say the end of the year for me is so crazy I do not have time so I had my local shop install... 2nd issue my wife looks at riding time and wrenching time as one in the same... That being said make sure you call and asked for updated instructions because the one on the website and in the box is not current... It took them 4 hours at the shop then a couple of hours of tuning ...
A
Arctic Kapp
235
47
the boat, CO
I ended up doing the install myself at the end of the season. Got a couple rides in, and never quit got it dialed in. Prolly get out in the next dump we get and play with the numbers. I kept throwing a DET code on my proclimb. We will see
B
Bacon
1,352
Napoleon, ND
What are you running for fuel? Might want to throw some octane at it.
sampo
New member
Apr 27, 2015
2
Where you have the fuel controller? Under the hood? Anyone have picture of ecu in new place?
wwillf01
2,790
616
Heber Ut
What elevation and what numbers on ur box are u running?
I had a long talk with silber then a talk with mds.... I am going to try the numbers they recommended for my altitude... This weekend then will try the clutch kit mds makes for turbo tree riding ... And will report back..
Sent from my XT1585 using Tapatalk
A
Arctic Kapp
235
47
the boat, CO
Yes, please do let me know
wwillf01
2,790
616
Heber Ut
OK swapped green spring for yellow stock and was using cutlers adjustable weights with 74 grams it worked much better than the green for boon docking ... Tomorrow riding with the mds set up... They use a Polaris black spring with his adjustable weights... He suggested 77 grams with his spring so I will report back.. Just loading into the trailer was 20 times better... Super incredibly smooth with mds... Keep in mind I run 7 pounds of boost and the stock fueling works way better from silber with the clutching changes ... No more midrange hicup...
Apr 2, 2014
12
10
3
Wi
I'd have to look to see my numbers, but it was very close to their baseline numbers on their website. Now working on transferring the kit to my 16'. I have the headlight deleted, ecu relocated(not real fond of it under the throttle body's) now just need to route my intake up to a snorkel
wwillf01
2,790
616
Heber Ut
OK guys here is my report... If you have a silber turbo and like the trees and boondocking ... Here are the steps to follow...
1. Buy the turbo
2. Open the box and throw out their clutching kit
3. Talk to Steve with mds and have him set you up with his spring and weights
4. Install and smile...
This is no exaggeration on my part the clutching is so much better it is a night and day difference ... I gained at least 1000 lower engagement and still revs smooth. My mid end bobble is gone. As it turns out silbers fueling is good once it's clutched right...
