Silber 13 Kit Low Elevation Numbers
X
XP Summit
Curious as to what dobeck numbers any of your low elevation guys are running for your 13 Silber Kits? Mine is on a 13 Pro RMK running 7-8 PSI, 1500 ft on 50/50 110 race/clean 91.
Took mine out for two days of riding in Minnesota with 3 ft of fresh and temps between -8 and 1. My first day out I ran Justin's recommend numbers. The sled would fall on it's face after I got off boost and back into the throttle. I would have to slowly give it a bunch of braaap, braaps to clean it up to get back on it. Called Justin he told me to raise red blue .5, lower yellow blue .5 to 1, lower yellow .5. and leave it on the ethanol setting. It helped it, but wasn't 100%. I would say I am about 70% of the way there.
The sled is a blast so far, just need to tune it, which I expected. I know I have seen some guys running 13 kits in AK and around here locally. Thanks for you input.
Cheers
Shawn
i have worked on a few of those kits and have T'd the Tmap sensor into the BOV line, so that it doesn't keep seeing boost pressure while the BOV bleeds it off when the throotle blades shut. i have had some sucess in doing that.
