should I change the helix on my secondary clutch
Thank You in advance for any responses! I have a 03 vertical escape and the helix is mangled thanks to the previous owner. I want to know if there is a different sized helix I should use rather than the stock one. I have to get a new one either way. The old one is 58-44-46er oem 5133687. Thanks again!
What else is done to the sled? If you dont have many other modifications then id just put another stock helix back in.
It just has a slp pipe and can and the exhaust valve springs are red. Other than that I think everything else is stock. Can I go with a 58=40-46er or should I stay with the 58-44-46er or go with something else? I am not sure it is going to make much difference, just don't want to screw it up. Thanks Again!
