Shim amount for clutch alignment?
Hello,
I have been looking around trying to find a guesstimate of how much shimming I will need under the front PTO motor mount to make up the .020" misalignment on my secondary clutch. With the spacing on my clutch alignment tool set at .085" the back is measuring out around .145".
I see information for rule of thumb notching amount when you are "notching your MAG side" engine bracket for when it is way out of alignment but I am only looking to take up about .020" of misalignment and would like to play as little of a game of guess and check as possible when removing the engine to install mount shims.
Thanks, Dan
