Shaft size
montanagrizzly
Anyone know what size the stock shaft is for a 01 800 rmk sp looking to get some antiratchets and need to know thanks alot!
im in the same boat i have 99 xc 700 and im wondering if i can put a complete set of drivers from a 2002 edge would fit in my chaincase and bearings thanks for any info
Shaft
The edge shaft will fit you may have to adjust your driver location. The diameter on the chaincase end is the exact same. I have an edge shaft in my 97 700. I have the bearings platesset up like an edge one on the inside, one on the outside, instead of the two outside the tunnel like my 97 700 had stock. just my .02. On the drivers, buy the 1", even if you have the 1 1/16, the drivers will still press on and be tighter.
